The Bus Pirate has a NAND flash chip for storing settings and data. The flash chip also appears as a USB flash drive when the Bus Pirate is connected to a computer. Sharing the chip between the Bus Pirate and the computer operating system is a bit tricky.
Internal storage commands
Linux-like commands are used to navigate the flash storage from the Bus Pirate command line.
  • ls List files
  • cd Change directory
  • mkdir Make directory
  • rm Remove file/directory
  • cat Print file contents as text
  • hex Print file contents in HEX
  • format Format storage disk (FAT16)
  • label get or set the disk label
These common commands are supported in the firmware as of this update, but always use help or ? to see the latest commands available. Add -h to any command for extended help: hex -h.
HiZ> ls
       350 bpconfig.bp
0 dirs, 1 files
Navigate the internal storage using typical Linux commands such as ls to list the contents of the current directory.
HiZ> mkdir temp
mkdir to create a new directory.
HiZ> cd temp
/TEMP
cd to change directory.
HiZ> cd ..
cd .. to move up one directory or cd / to return to the root directory.
HiZ> ls
       350 bpconfig.bp
   <DIR>   temp
1 dirs, 1 files
ls shows the new temp folder was created.
HiZ> rm temp
rm removes files and directories.
HiZ> ls
       350 bpconfig.bp
0 dirs, 1 files
HiZ>
ls once more to verify the temp directory has been deleted.
USB Flash Drive Use
Sharing the NAND chip between the Bus Pirate and a computer is a bit tricky. The USB mass storage driver doesn’t have a mechanism to signal when changes are made to the disk, leading to data corruption. This is why e.g. Android uses MTP protocol for file transfer.
To keep the Bus Pirate and the computer happy, and prevent data corruption, we use a bit of trickery. This can seem odd if you don’t expect it.
Read Only Mode
When a terminal is connected to the Bus Pirate, the flash storage appears as a read only disk to the computer.
  • Bus Pirate has read/write access to the disk
  • The computer can read files from the disk
  • The computer can’t write to the disk
  • The disk with re-attach after file changes
Let’s elaborate on the last point. When the Bus Pirate makes changes to the flash - say saving a configuration file or dumping a flash chip - the drive will detach from the PC and then re-attach. This is to ensure that the computer sees the updated contents.
Read/Write Mode
When a terminal is not connected, the flash storage appears as a read/write disk to the computer. You can copy and delete files as you would with any other USB flash drive.
