TeraTerm setup
Plug in the Bus Pirate
Connect the Bus Pirate to your computer with a USB C cable.
The Bus Pirate currently appears as three USB devices:
  • USB CDC class device 0: an emulated serial port for accessing the user terminal
  • USB CDC class device 1: an emulated serial port for accessing the binary scripting interface
  • USB Mass Storage Device: a disk drive interface for accessing onboard storage
These are common device classes and recent operating systems will not request or require a driver. We’re living in the future, woohoo!
Connect with a terminal emulator
A terminal emulator is software that connects to the Bus Pirate serial interface and displays the command line. The Bus Pirate supports VT100 for a colorful interface with a live view statusbar. A fallback monochrome ASCII mode is also available. Most terminal emulators support VT100, it’s been around since the 1970s.
Common issues
