Pull-up Resistors and IO
Protocols such as I2C and 1-Wire use open collector outputs for two way communication on a single data wire. In this type of protocol there is no 1/high level without a pull-up resistor. The pull-up resistor connects to a voltage that “pulls” the wire high. Devices use their output to ground the wire and pull it low.
The Bus Pirate has 10KΩ onboard pull-up resistors that can be toggled with the p and P commands.
Overview
| Command | Description |
p | Disable pull-up resistors. |
P | Enable pull-up resistors. |
a X | Set pin X to output and low. |
A X | Set pin X to output and high. |
@ X | Set pin X to input. |
W | Enable the power supply, configure voltage and current limit. |
Enter LED mode
This tutorial uses LED mode configured for the onboard LEDs, see Blink Some LEDs tutorial. In this mode all the Bus Pirate IO pins are free for experimenting.
See the ‘Blink Some LEDs’ tutorial to enter and configure LED mode.
Voltage Source
The pull-up resistors are powered by the voltage on the VOUT/VREF pin. This can come from two sources:
- The onboard programmable power supply unit
- Externally through the VOUT/VREF pin on the Bus Pirate main connector
For this tutorial let’s use the onboard power supply.
Programmable Power Supply Unit
LED-()> W 5 100 5.00V requested, closest value: 5.00V 100.0mA requested, closest value: 100.0mA Power supply:Enabled Vreg output: 5.00V, Vref/Vout pin: 5.00V, Current: 2.3mA LED-()>
Enable the power supply, this will power the pull-up resistors and the IO buffers.
Here, we use W 5 100 to quickly enable a 5 volt supply and 100mA current limit fuse.
You can also use the W command with no options to see the configuration menu.
Check the live view statusbar at the bottom of the terminal.
- The top line indicates the power supply is set at 5 volts with a 100mA current limit.
- The third line shows that 7.8mA is being consumed on VOUT. Since nothing is connected this represents the IO buffer current, base current of the PPSU, op-amp offset error and noise in the RPi chip analog to digital converter.
- The last line shows that VOUT currently measures 5volts, and other pins measure 0 volts.
External Power Supply
Hacking a device with its own power supply? You can use that instead.
- Connect the device power to the Bus Pirate VOUT/VREF pin
- Connect the device ground to the Bus Pirate ground pin.
The Bus Pirate is rated for 5volts DC maximum. Exceeding this limit will damage the Bus Pirate and your computer.
Enable Pull-up Resistors
LED-()> P Pull-up resistors: Enabled (10K ohms @ 5.0V) LED-()>
Type uppercase P followed by enter to activate the pull-up resistors.
In the live view statusbar all pins should be high, close to 5.0 volts.
- The top line now shows that the pull-up resistors are enabled.
- The bottom line shows that IO0 to IO7 all measure 4.9 volts.
4.9volts isn’t exactly 5, but that’s not a problem.
Controlling IO Pins
Sometimes it’s helpful to toggle or read a pin. The a/A/@ commands toggle the Bus Pirate pins low, high and input.
Auxiliary Pins Low
LED-()> a 0 IO0 set to OUTPUT: 0 LED-()> a 1; a 2; a 3; IO1 set to OUTPUT: 0 IO2 set to OUTPUT: 0 IO3 set to OUTPUT: 0 LED-()>
a 0 configures IO 0 as output and low. Multiple commands can be chained with the ;, || and && operators.
- Type
a 0; a 1; a 2; a 3and pressenterto configure IO0 to IO3 as output and low.
Verify that the pins are low in the live view statusbar if active, or use the v command to view a voltage report.
- The third line shows that IO0 to IO3 are configured as auxiliary-low (AUXL).
- The last line shows that IO0 to IO3 now measure close to ground (0.1volt).
Auxiliary Pins Input
LED-()> @ 0; @ 1; @ 2; @ 3 IO0 set to INPUT: 1 IO1 set to INPUT: 1 IO2 set to INPUT: 1 IO3 set to INPUT: 1
@ X makes the corresponding Bus Pirate pin an input, allowing the pull-up resistors to hold the pin high again.
- Type
@ 0; @ 1; @ 2; @ 3followed byenter.
@ X also reads the state of the input pin. In this case the Bus Pirate reads ‘1’ because the pull-up resistors are holding the pin high.
Verify that all the pins are around 5volts in the live monitor statusbar, or by using the voltage report command v.
- All pins should be pulled high again.
Disable Pull-ups
LED-()> p Pull-up resistors: Disabled LED-()>
- Type lowercase
pthen hitenterto disable the pull-up resistors.
Verify that all the pins show 0volts in the live monitor statusbar or voltage report.
- All pins should now be at 0volts because the pull-up are disabled.
Auxiliary Pins High
LED-()> A 0 IO0 set to OUTPUT: 1 LED-()>
A X sets the corresponding Bus Pirate pin to output and high.
- Type
A 0followed byenterto set IO0 high. - The live view statusbar should show that IO0 is now high (AUXH) and measures 5 volts.
