Programmable Power Supply
The Bus Pirate has a ‘Programmable Power Supply Unit’ (PPSU) that can power devices from the VOUT/VREF pin of the main connector.
- 1-5volts adjustable output, 300mA max
- 0-500mA current sense
- 0-500mA current limit with digital fuse
- Backflow prevention to protect the PPSU when an external voltage is applied to the VREF/VOUT pin
Overview
| Command | Description |
W | Enable the power supply, configure voltage and current limit. |
w | Disable the power supply. |
v | Show the power supply voltage report. |
Enable
I2C> W Power supply Volts (0.80V-5.00V) x to exit (3.30) > 5 Maximum current (0mA-500mA), 0 for none x to exit (300) > 100 5.00V requested, closest value: 5.00V 100.0mA requested, closest value: 100.0mA Power supply:Enabled Vreg output: 5.0V, Vref/Vout pin: 5.0V, Current: 3.0mA I2C>
Enter any protocol mode (m) to use the power supply. The power supply is always disabled in HiZ safe mode.
Type uppercase W followed by enter to enable the power supply.
- Enter the desired output in volts, for example
5followed byenter. - Enter the desired current limit in milliamps, for example
100followed byenter.
The Bus Pirate will calculate the closest possible values and enable the PPSU.
Press enter to accept the default values of 3.3 volts and 300mA current limit fuse.
Quick enable
I2C> W 5 100 5.00V requested, closest value: 5.00V 100.0mA requested, closest value: 100.0mA Power supply:Enabled Vreg output: 5.0V, Vref/Vout pin: 5.0V, Current: 2.3mA
The W command accepts voltage and current as command line options. W 5 100 is equivalent to the previous example.
- The first parameter specifies the voltage
- The second parameter specifies the current limit (omit for no current limit)
I2C> W 5 5.00V requested, closest value: 5.00V Current limit:300mA
Omit the second parameter for the default 300mA current limit fuse.
Check voltage and current
Check the voltage and current in the live view statusbar if active, or show the power supply voltage report using the v command followed by enter.
- The top line indicates the power supply is set at 5.0 volts with a 100mA current limit.
- The third line shows that 2.1mA is being consumed on VOUT/VREF. Since nothing is connected this is the power used by the IO pin buffers, current leakage, offset error and noise in the RP chip’s analog to digital converter.
- The last line shows that VOUT currently measures 5.0 volts, and all IO pins measure 0 volts.
300mA is the rated maximum of the PPSU, but we added some headroom in the current limit to account for current spikes.
Current limit
I2C> W 5 10 5.00V requested, closest value: 5.00V 10.0mA requested, closest value: 10.0mA Power supply:Enabled Vreg output: 5.0V, Vref/Vout pin: 5.0V, Current: 2.3mA I2C> Error: Current over limit, power supply disabled I2C>
When the programmed current limit is exceeded the PPSU hardware fuse disables the power supply.
- The terminal colors invert repeatedly.
- An alarm bell sounds
- An error message is shown
- Command execution is halted.
Use the W command to restart the PPSU again, or the w command to disable.
Test the current limit:
- Set the current limit to 10mA
- Connect a wire from the VOUT pin to the GND pin.
The Bus Pirate will disable the power supply when the current exceeds 10mA.
Disable
I2C>w Power supply: Disabled I2C>
Lowercase w disables the PPSU.
