On this page
Configuration Menu
HiZ> c Configuration options 1. Language / Jezik / Lingua 2. ANSI color mode 3. ANSI toolbar mode 4. LCD screensaver 5. LED effect 6. LED color 7. LED brightness x. Exit >
Type c
followed by enter
to show the Bus Pirate configuration menu. These options control things like the language, live view statusbar and LEDs.
Configuration
> 5 LED effect 1. Disable 2. Solid 3. Angle wipe 4. Center wipe 5. Clockwise wipe 6. Top side wipe 7. Scanner 8. Gentle glow 9. Party mode x. Exit > 9 LED effect set to Party mode
Type a menu option number followed by enter
. Choose a configuration setting by typing the number followed by enter
Exit and Save
x. Exit > x Configuration file: Saved
Press x
followed by enter
at any prompt to exit the configuration menu.
Settings file
HiZ> ls 350 bpconfig.bp 0 dirs, 1 files
Settings are saved in bpconfig.bp and will load automatically when the Bus Pirate restarts.
HiZ> cat bpconfig.bp
"terminal_language": 0,
"terminal_ansi_color": 1,
"terminal_ansi_statusbar": 0,
"display_format": 0,
"lcd_screensaver_active": 0,
"lcd_timeout": 0,
"led_effect": 8,
"led_color": "0xFF0000",
"led_brightness_divisor": 10,
All Bus Pirate config files contain simple JSON formatted data.
