alt text
One fabulous I2C quick connect adapter to rule them all! The quick connect adapter combines the most popular I2C breakout standards in one Bus Pirate compatible plank.
I2C is a simple communication protocol used by many sensors and devices. Over the years, manufacturers created “standard” I2C breakout board connectors for quick solder-free prototyping. All have the same basic four connections: power (V+), ground (GND), I2C Serial Data (SDA), and I2C Serial Clock (SCL). However, the pinout and connector types vary.
I2C Breakout Standards
Pinout Table
PinStemma 3PStemma 4PStemma QTQwiicGroveGravityBreakout Garden
1SIGNALSCLGNDGNDGNDSDAV+
2V+SDAV+V+V+SCLSDA
3GNDVOUTSDASDASDAGNDSCL
4GNDSCLSCLSCLV+INT
5GND
Connector Types
StandardConnectorPitchExample Part Number
Stemma 3PJST PH 3P2.0mmJST: S3B-PH-SM4-TB, Generic: HC-PH-3AWT
Stemma 4PJST PH 4P2.0mmJST: S4B-PH-SM4-TB, Generic: HC-PH-4AWT
Stemma QTJST SH 4P1.0mmJST: SM04B-SRSS-TB, Generic: HC-1.0-4PWT
QwiicJST SH 4P1.0mmJST: SM04B-SRSS-TB, Generic: HC-1.0-4PWT
Grove“HY” 4P2.0mmHY-4P, HY2.0-4P-SMD, A2008WR-S-4P
GravityJST PH 4P2.0mmJST: S4B-PH-SM4-TB, Generic: HC-PH-4AWT
Breakout GardenPCB edge slot conn. 2 x 5P2.54mmED10BGFBK
Thanks!
A huge thank you to Funcan, kd7eir, grymoire, and henrygab for testing the various connectors with genuine breakout boards!
