KF141 Quick Connector
Sometimes you just need to connect some wires and dig into a project. Quick connector boards get you working right away.
KF141 is a popular quick connector block with sturdy spring retention clamps. Press the lever, insert a stripped wire, then release the lever to clamp it firmly in place. Pin names are silkscreened in bright orange so you get the right connection the first time. Made with the highest quality KF141 we could source.
KF141-R right angle connector
KF141-R is a right angle connector. Wires clamps are oriented to the front of the connector block. Pin names are silkscreened in bright orange to save time and hassle.
KF141-V vertical connector
KF141-V is a vertical connector. Wires clamps are oriented to the top of the connector block. Pin names are silkscreened in bright orange to save time and hassle.
- KF141-Right Angle Adapter Schematic and PCB
- KF141-Vertical Adapter Schematic and PCB
- Development in the forum
