REV 8 was produced in a small prototype production batch (August 2023) and an initial production batch (September 2023). Check your Bus Pirate 5 PCB to find your revision number located near the TF flash card (bottom) and the 10 pin connector (top). We intend to move to REV 9 (BOM cleanup) as soon as validation and FCC testing are completed. There are no feature changes in REV 9, just tweaks to the supplier list.
šŸ›’
Change Log
  • Preview production batch
Bill of Materials
BrandPartPackageDescriptionReel QuantitySupplier
SAMSUNG(äø‰ę˜Ÿ)CL05B104KO5NNNC0402100nF ±10% 16V10000SZRCD
SAMSUNG(äø‰ę˜Ÿ)CL05C150JB5NNNC040215pF ±5% 50V10000SZRCD
SAMSUNG(äø‰ę˜Ÿ)CL05A225MP5NSNC04022.2uF ±20% 10V10000SZRCD
SAMSUNG(äø‰ę˜Ÿ)CL05A475KP5NRNC04024.7uF ±10% 10V10000SZRCD
SAMSUNG(äø‰ę˜Ÿ)CL05C121JB5NNNC0402120pF ±5% 50V10000SZRCD
UNI-ROYAL(厚声)0402WGF1003TCE0402100K ±1%10000SZRCD
UNI-ROYAL(厚声)0402WGF1023TCE0402102K ±1%10000SZRCD
UNI-ROYAL(厚声)0402WGF1002TCE040210K ±1%10000SZRCD
UNI-ROYAL(厚声)0402WGF1333TCE0402133K ±1%10000SZRCD
UNI-ROYAL(厚声)0402WGF1001TCE04021K ±1%10000SZRCD
UNI-ROYAL(厚声)0402WGF2000TCE0402200R ±1%10000SZRCD
UNI-ROYAL(厚声)0402WGF220JTCE040222R ±1%10000SZRCD
UNI-ROYAL(厚声)0402WGF3300TCE0402330R ±1%10000SZRCD
UNI-ROYAL(厚声)0402WGF3302TCE040233K ±1%10000SZRCD
UNI-ROYAL(厚声)0402WGF1003TCE04025.1K ±1%10000SZRCD
UNI-ROYAL(厚声)4D02WGJ0104TCE0402x4100K ±5%10000SZRCD
UNI-ROYAL(厚声)4D02WGJ0103TCE0402x410K ±5%10000SZRCD
UNI-ROYAL(厚声)4D02WGJ0105TCE0402x41M ±5%10000SZRCD
UNI-ROYAL(厚声)4D02WGJ0331TCE0402x4330R ±5%10000SZRCD
UNI-ROYAL(厚声)0805W8J0330T5E080533R ±5%5000SZRCD
Ta-i Technology (å¤§ęÆ…ē§‘ęŠ€)RLP25FEER20025150R2 ±1% 2W4000SZRCD
TDKMLZ1608M220WT000060322uH 155mA (surge)4000SZLCSC
Sunlord (锺络)GZ2012U300TF08051.5A Ferrite bead4000Dodgy supplier
CBI (åˆ›åŸŗ)1N4148WS T4SOD-323100V 150mA3000CBI (åˆ›åŸŗ)
YXC (ę‰¬å…“ę™¶ęŒÆ)X322512MSB4SI322512MHz ±10ppm 20pF3000Navia
CBI (åˆ›åŸŗ)2N7002SOT-23NFET3000CBI (åˆ›åŸŗ)
WINSOK(微甕)WST3423SOT-23PFET3000SZLCSC
DIODES(ē¾Žå°)BCM857SOT-363/SC-70-6Dual PNP matched pair3000SZLCSC
CBI (åˆ›åŸŗ)MMDT3906SOT-363/SC-70-6Dual PNP3000CBI (åˆ›åŸŗ)
MICRONE(å—äŗ¬å¾®ē›Ÿ)ME6211A33PG-NSOT-89-33.3V VREG1000Navia
DIODES(ē¾Žå°)AP2127K-ADJTRG1SOT-23-50.8V-5.5V 300mA VREG3000Navia
Gainsil(聚擵)GS6001-TRSOT-23-5R2R op-amp3000Navia
RUNIC(润石)RS8901XFSOT-23-5Comparator3000Navia
Raspberry PiRP2040QFN-56500SZLCSC
WinbondW25Q128JVSIQSOP-8128Mbit2000SZLCSC
Nexperia74HC4066PWTSSOP-144 channel analog switch2500SZHXKC
Nexperia74HC595PWTSSOP-16Shift register2500SZHXKC
Nexperia74HCT245PWTSSOP-20Level converter2500SZHXKC
Nexperia74HC4067PWTSSOP-2416 channel analog mux2500SZHXKC
TISN74LVC1T45DCKSOT-363/SC-70-6Buffer3000SZHXKC
CGL LEDSK6812-mini-eLED down facing2000CGL LED
CGL LEDSK6812-side-a_bLED side facing2000CGL LED
SZHTCQT200H1201320x240 DisplaySZHTC
KAIDITJC8-10AW1x10 P2.54mm horizontal male1000KAIDI
SZWG1x03 P2.54mm vertical female1x03 P2.54mm vertical femaleSZWG
SZYC1.0-9P WTTube1x09 P1.00mm horizontal maleSZYC
YUANDI(å…ƒčæŖ)TF-01ATF flash card socket1000YUANDI(å…ƒčæŖ)
SHOU HAN(首韩)TYPE-C-31-M-12USB C 16P1000SHOU HAN(首韩)
SHOU HAN(首韩)TS3425BA 098 2.5H 250gf4.2x3.4x2.5mm4x3x2.5H button 250gf3000SHOU HAN(首韩)
SHOU HAN(首韩)TS3315A 250gf 0253.3x3.3x1.5mm3x3x2.5H button 250gf4000SHOU HAN(首韩)
šŸ›’
