Logo Image
  • Download Firmware
  • Command Reference
    • Bus Pirate Hardware
    • Probe Cable Kit
    • Auxiliary Cable Kit
    • KF141 Quick Connector
    • SPI Flash Adapters
    • Dual RS 232 Adapter
    • IC Card and SIM Adapter
    • USB Power Delivery Adapter
    • Infrared RX/TX Toy
    • Qwiic, Stemma (3P/4P/QT), Breakout Garden, Grove I2C Adapter
    • DDR5 RAM SPD I2C Adapter
    • Programming Voltage SMPS
    • CAN Bus Adapter
    • PS/2 & USB Sniffer Adapter
    • Probes and Hooks
    • IO Pin Descriptions
    • Quick Setup
    • Upgrade Firmware
    • Blink Some LEDs
    • Programmable Power Supply
    • Pull-up Resistors and IO
    • Configuration Menu
    • Self-test Procedure
    • USB Flash Storage
    • DS18B20 Temperature Sensor 1-Wire
    • Mobile SIMs & Bank IC Cards HDUART
    • 24C02 Smart IC Card I2C
    • MB85RC256V FRAM memory I2C
    • DDR5 SDRAM module I2C
    • DDR4 SDRAM module I2C
    • SHT30, SHT31 and SHT35 Humidity & Temperature I2C
    • SHT40, SHT41, SHT43 and SHT45 Humidity & Temperature I2C
    • SI7021, HTU21, SHT21 Humidity & Temperature I2C
    • TCS3472x color sensor I2C
    • AT24C256 EEPROM I2C
    • TSL2561 LUX Sensor I2C
    • W25QXXX NOR Flash Chips SPI
    • W25Q64 NOR FLASH SPI
    • SLE4442 Smart IC Card 2WIRE
    • WS2812/SK6812/NeoPixel LED
    • APA102/SK9822 LED
    • NMEA GPS module UART
    • IR Remote Control INFRARED
    • JTAG & SWD Pin Finder JTAG
    • UART Glitch of Arduino
    • Identify Serial EEPROM, Flash and FRAM chips
    • Available Logic Analyzers
    • PulseView (Normal)
    • PulseView (Follow Along)
    • Logic Command
  • Oscilloscope
    • AVRDUDE Programmer
    • Flashrom
    • AnalysIR Infrared RX/TX
    • SUMP Logic Analyzer
    • Follow Along Logic Analyzer
    • Legacy Raw SPI (Flashrom and AVRdude)
    • aIR AnalysIR RX/TX
    • BPIO2 FlatBuffers Interface
      • bp_cmd Data Types
      • bp_cmd Parsing API
      • bp_cmd Interactive Prompting
      • bp_cmd Linenoise Integration
      • bp_cmd Patterns & Recipes
      • Syntax & Bytecode Pipeline
      • Translation & Localization
      • Build System & Targets
      • Board Abstraction & Platform Porting
      • Dual-Core Architecture
      • Pin & BIO System
      • Storage & Persistence
      • USB & Communication
      • system_config Reference
      • System Monitor & Power Supply
      • Error Handling Conventions
      • Implementing a New Binary Mode
      • Adding a New Display Mode
      • Host-Side Testing
      • Adding a New Mode
      • Adding a New Command
    • Firmware Development
    • Writing Documentation
    • Translation
    • JSON Configuration Files
      • Bus Pirate 5 Specs
      • Hardware Design (5 REV 10)
      • Bill of Materials (5 REV 10)
        • Introduction
        • Passives
        • Transistors and MOSFETs
        • Voltage Regulators
        • Analog Components
        • Chips
        • Crystal
        • LEDs and Display
        • Connectors
        • Switches
        • Printed Circuit Board
      • Bus Pirate 6 Specs
      • Hardware Design (6 REV 2)
      • RP2350 Preview & Launch
      • Hardware Design (5 REV 8)
      • Bill of Materials (5 REV 8)
        • Introduction
        • Passives
        • Analog Components
        • Chips
        • Crystal
        • LEDs and Display
        • Connectors
        • Switches
    • Cables
    • Milled Breadboard Pins
    • Enclosure
    • FDM Shell (3D print)
    • SLA Shell (3D print)
    • Injection Molded Shell v1
    • Injection Molded Shell v2
    • Button Caps
    • Final Assembly
    • Testing
      • Materials
      • Scratch & Sniff Sticker
      • Bus Pirate 5 Pack
      • Probe Cable Pack
      • Auxiliary Cables Pack
      • Bus Pirate 5 preview PCB only
      • Introduction
      • Prepare Position File
  • License
    Bus Pirate Get Downloads Docs Forum Contact
    • to navigate
    • to select
    • to close
      • Home
      • Device Demos
      On this page
      info
      This is a placeholder for the a new device demo.
      navigate_before NMEA GPS module UART
      JTAG & SWD Pin Finder JTAG navigate_next
      All Bus Pirate Hardware
      Find a Distributor
      Quick Links
      Downloads
      BlueSky
      Forum
      Instagram
      Mastodon
      X (Twitter)
      More
      Blog
      Contact
      GitHub
      Copyright © 2026 Where Labs, LLC. Bus Pirate™ is a trademark of Where Labs, LLC.
