The Bus Pirate eeprom and flash commands can read, write, erase, verify and test many common serial memory chips: SPI Flash (25Q), SPI EEPROM (25x, 95x), I2C EEPROM (24x), 1-Wire EEPROM, Microwire EEPROM (93x), SPI FRAM and I2C FRAM.
This page will help you identify the type of serial memory chip you have, the pinout, and the voltage requirements.
Types of Serial memory supported
TypePart Number*Ex. Part Num.Example Manufacturers
SPI Flash25QnnnW25Q128Winbond, Micron, GigaDevice, PUYA
SPI EEPROM25xnnn, 95xnnn25LC040, AT25040Microchip, Atmel, STMicroelectronics
I2C EEPROM24xnnn24LC20, AT24C02Microchip, Atmel, STMicroelectronics
1-Wire EEPROM243nDS2341, GX2341, DS24B33Dallas/Maxim, GX
Microwire EEPROM93xnnAT93C46, 93LC56CMicrochip, Atmel, STMicroelectronics
SPI FRAMFM25xnnn, MB85XnnnFM25CL64B, MB85RS512Ramxeed (Fujitsu), Infineon, ROHM
I2C FRAMFM24xnnn, MB85XnnnFM24CL64B, MB85RC64Ramxeed (Fujitsu), Infineon, ROHM
*n = device size in Kbits, usually.
SPI Flash Memory
SPI Flash chips use NOR memory, which is cheap, fast, and small. There are several trade offs though:
  • Size: 1 Mbit to 512 Mbit (128K - 64M)
  • Read: Not byte addressable, data must be read in whole pages (usually 256 bytes) at a time.
  • Write: Not byte addressable, data must be written in whole pages (usually 256 bytes) at a time and page aligned.
  • Erase: Data must be erased in whole sectors (usually 4K, 8K or 64K) at a time.
  • Cost: SPI Flash is cheap!
  • Write cycles: 10,000+
  • Data retention: 20 years
To update existing data, you must first read all the data in the erase sector, modify it in RAM, erase the whole 4K sector, and then write it back to the flash memory.
Identifying SPI Flash chips
A really common SPI Flash chip is the Winbond W25Qnnn series. It will be labeled with the Winbond logo and the part number will start with “W25Q” followed by a three digit number indicating the size in Mbits.
Most recent SPI flash chips have their characteristics stored in JEDEC standard SFDP (Serial Flash Discoverable Parameters) format. The flash command in SPI mode will automatically read the SFDP data and display the chip characteristics, including the manufacturer, size, erase sector size, and other parameters.
If SFDP data isn’t available, the flash command has a database of known chips and can identify them by their JEDEC ID.
SPI Flash pinout
alt text
PinNameDescriptionPinNameDescription
1CSSPI Chip Select (active low)8VCCPower supply
2SOSPI Serial Out (MISO)7HOLDHold (active low)*
3WPWrite Protect (active low)*6SCKSPI Serial Clock
4GNDGround5SISPI Serial In (MOSI)
Write protect pin
The write protect pin is optional, and may not be present on all chips. If it is present, it is used to protect the chip from being written to. If the pin is connected to ground, the chip can be written to. If the pin is connected to VCC, the chip is write protected and cannot be written to.
Hold pin
The hold pin is also optional, and may not be present on all chips. If it is present, it is used to pause the chip’s operation without resetting it. If the pin is connected to ground, the chip will pause its operation until the pin is released.
Image source: Winbond W25Q128JV datasheet
SPI Flash voltage requirements
FamilyMinimum VoltageMaximum Voltage
W25Q2.7V3.6V
EEPROM memory
Unlike Flash (NOR) memory, EEPROM memory is byte-addressable and can be written to one byte at a time.
  • Size: 1Kbit to 4 Mbit (128B - 512K)
  • Read: Byte addressable, can read any byte in the chip.
  • Write: 1 byte up to the page size (8 to 256 bytes, depending on chip) at a time. Writes must be aligned to the page size.
  • Erase: No separate erase process is needed, bytes are erased individually before writing.
  • Cost: EEPROM is generally more expensive than NOR Flash memory.
  • Write cycles: 1,000,000+
  • Data retention: 100-200 years
Identifying SPI EEPROM chips
SPI EEPROM chips are usually labeled with a part number starting with “25” or “95”. The “25” series is more common and includes chips like AT25C020, 25LC040, 25AA080, etc. The “95” series is STM’s name for their 25x compatible EEPROMs, just substitute the same sized 25x part, e.g. 25LC040 is equivalent to 95LC040.
DeviceDensitySize (bytes)Page Size (Bytes)Address BytesBlock Select BitsB.S. Offset
25X0101 Kbit1288(AT)/1610
25X020**2 Kbit2568(AT)/1610
25X040**4 Kbit5128(AT)/16113
25X0808 Kbit102416/32(AT,STM)20
25X16016 Kbit204816/32(AT,STM)20
25X320**32 Kbit40963220
25X640**64 Kbit81923220
25X128**128 Kbit163846420
25X256**256 Kbit327686420
25X512**512 Kbit6553612820
25XM01, 25X1024**1 Mbit13107225630
25XM022 Mbit26214425630
25XM04**4 Mbit524288256/512(STM)30
**Tested devices
SPI EEPROM pinout
alt text
Write protect pin
Hold pin
Image source: Microchip 25x512 datasheet
SPI EEPROM voltage requirements
25x/95x FamilyMinimum VoltageMaximum Voltage
AT251.8V5.5V
25LC2.5V5.5V
25AA1.8V5.5V
25CS1.7V5.5V
M952.5V5.5V
Identifying I2C EEPROM chips
I2C EEPROM chips are usually labeled with a part number starting with “24”. The “24” series includes chips like 24LC02, 24AA04, AT2402 etc. The “24” series is the most common I2C EEPROM series.
DeviceSizeSize (bytes)Page SizeAddress BytesBlock Select BitsBlock Select Bit Offset
24x01**1 Kbit128810
24x02**2 Kbit256810
24x04**4 Kbit51216110
24x08**8 Kbit102416120
24x16**16 Kbit204816130
24x32**32 Kbit40963220
24x64**64Kbit81923220
24x128**128 Kbit163846420
24x256**256 Kbit327686420
24x512**512 Kbit6553612820
24x10251 Mbit131072128213
24x10261 Mbit131072128210
24xM01**1 Mbit131072256210
24xM022 Mbit262144256220
**Tested devices
I2C EEPROM pinout
alt text
1A0Address select pin 0*8VCCPower supply
2A1Address select pin 1*7WPWrite protect*
3A2Address select pin 2*6SCLI2C Clock line
4GNDGround5SDAI2C Data line
Address select pins
These pins are optional, and may not be present on all chips. If they are present, they are used to select the I2C address of the chip. The address is 7 bits, with the last bit being the read/write bit. The address is determined by the state of these pins, e.g. A0=0, A1=0, A2=0 gives 7-bit address 0x50, A0=1, A1=0, A2=0 gives address 0x51, etc.
Write protect pin
The write protect pin is also optional, and may not be present on all chips. If it is present, it is used to protect the chip from being written to. If the pin is connected to ground, the chip can be written to. If the pin is connected to VCC, the chip is write protected and cannot be written to.
Image source: Microchip 24x512 datasheet
I2C EEPROM voltage requirements
24xx FamilyMinimum VoltageMaximum VoltageNotes
AT24C2.7V5.5V400kHz max
24LC2.5V5.5V400kHz max
24AA1.7V5.5V400kHz max
24FC1.8V5.5V1MHz max
Identifying 1-Wire EEPROM chips
1-Wire EEPROMs are slightly different than SPI and I2C EEPROMs. Writes must be a full page (8 or 32 bytes) at a time, and they have much lower write cycles and data retention than SPI or I2C EEPROMs.
  • Write: A full page (8 or 32 bytes), write aligned to the page size.
  • Write cycles: 200,000
  • Data retention: 10-25 years
1-Wire EEPROM chips are usually labeled with a part number starting with “243”. The “243” series includes chips like DS2431, DS2432, GX2341, DS24B33, etc. The “243” series is the only known series of 1-Wire EEPROMs.
DeviceSizeBytesPage SizeAddr BytesBlk Sel BitskHz max
DS2431**1K12882016
DS24B33**4K512322016
**Tested devices
1-Wire EEPROM voltage requirements
DS243X2.8V5.25V
Identifying Microwire EEPROM chips
Microwire EEPROM chips are ancient technology that persists today. Microwire EEPROMs are also byte-addressable and can be written to one byte at a time. They use a funky version of SPI and have a drastically different pinout.
Microwire EEPROM chips are usually labeled with a part number starting with “93”. The “93” series includes chips like 93C46A, 93C56B, 93C66C, etc.
DeviceSizeBytesOrganizationDummy bitsAddressTotal bits
93x46A**1Kbit128x8 only07bits10
93x46B**1Kbit128x16 only06bits9
93x46C/E**1Kbit128x8 or x1607 or 6bits10 or 9
93x56A**2Kbit256x8 only18bits12
93x56B**2Kbit256x16 only17bits11
93x56C**2Kbit256x8 or x1618 or 7bits12 or 11
93x66A**4Kbit512x8 only09bits12
93x66B**4Kbit512x16 only08bits11
93x66C**4Kbit512x8 or x16010 or 9bits12 or 11
93x76A8Kbit1024x8 only110bits14
93x76B8Kbit1024x16 only19bits13
93x76-/C8Kbit1024x8 or x16110 or 9bits14 or 13
93x86A**16Kbit2048x8 only011bits14
93x86B**16Kbit2048x16 only010bits13
93x86-/C**16Kbit2048x8 or x16011 or 10bits14 or 13
**Tested devices
Microwire EEPROM pinout
alt text
1CSSPI Chip Select (active HIGH)8VCCPower supply
2CLKSPI Clock7NCNot Connected
3DISPI Data In (MOSI)6ORGAddress mode*
4DOSPI Data Out (MISO)5GNDGround
Chip Select pin
The chip select pin is active high, which is different than most SPI devices.
ORG pin
The ORG pin is used to select the addressing mode of the chip. It is only present on “C” part numbers.
  • LOW/GROUND: 8-bit addressing
  • HIGH/VCC: 16-bit addressing
Image source: Microchip 93xx46 datasheet
Microwire EEPROM voltage requirements
93C4.5V5.5V
M93C2.5V5.5V
93LC2.5V5.5V
93AA1.8V5.5V
AT93C2.7V5.5V
FRAM Memory
SPI FRAM chips are a type of non-volatile memory that uses ferroelectric RAM technology. They are faster than EEPROM and Flash. FRAM can be written one byte at a time, or continuously without stop. FRAM has a very high write endurance and can be used in applications that require frequent writes.
  • Write: Continuous write, can write any byte in the chip. No concept of pages or sectors.
  • Cost: FRAM is the most expensive memory in wide spread use, but is becoming more affordable.
  • Write cycles: 10^15+ (1,000,000 times more than EEPROM)
  • Data retention: 100+ years
Identifying SPI FRAM chips
SPI FRAM chips are usually labeled with a part number starting with “FM25” or “MB85”. The “FM25” series includes chips like FM25CL64B, FM25L04B, etc. The MB85RS series is Infineon’s name for their FRAM chips, e.g. MB85RS512.
Identifying I2C FRAM chips
I2C FRAM chips are usually labeled with a part number starting with “FM24” or “MB85”. The “FM24” series includes chips like FM24CL64B, FM24L04B, etc. The MB85RC series is Infineon’s name for their FRAM chips, e.g. MB85RC64.
FRAM voltage requirements
FM252.7V3.65
FM242.7V3.65
MB852.7V3.6V
