• Bus: Half-duplex UART, MIDI (universal asynchronous receiver transmitter), RX and TX on the same wire
  • Connections: one data pin (RXTX) and ground
  • Output type: open collector - pull-up resistors required
  • Maximum Voltage: 5volts
Bus PirateDirectionCircuitDescription
RXTX←→RXTXBus Pirate Transmit and Receive
GNDGNDSignal Ground
Configuration options
UART speed
 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200 etc
 x. Exit
Baud (115200*) >
Data bits
 5 to 8 bits
 x. Exit
Bits (8*) >
Parity
 1. None*
 2. Even
 3. Odd
 x. Exit
Parity (1) >
Stop bits
 1. 1*
 2. 2
 x. Exit
Bits (1) >
Mode: HDPLXUART
HDPLXUART>
Pull-up resistors
Half-duplex UART is an open-collector bus, it requires pull-up resistors to hold the data line high to create the data ‘1’. The Bus Pirate doesn’t output high, it only pulls low. Without pull-up resistors there can never be a ‘1’.
Enable the Bus Pirate onboard pull-up resistors with the P command.
Syntax
CommandDescription
[Open UART, use r to read bytes.
{Open UART, display data as it arrives asynchronously.
] or }Close UART.
rCheck UART for byte, or fail if empty. (r:1…255 for bulk reads)
0bWrite this binary value. Format is 0b00000000 for a byte, but partial bytes are also fine: 0b1001.
0xWrite this HEX value. Format is 0x01. Partial bytes are fine: 0xA. A-F can be lower-case or capital letters.
0-255Write this decimal value. Any number not preceded by 0x or 0b is interpreted as a decimal value.
spaceValue delimiter. Use a space to separate numbers. No delimiter is required between non-number values: {0xa6 0 0 16 5 0b111 0xaF rrrr}.
(#)Run macro, (0) for macro list.
Bus Pirate 5 has global commands available everywhere, and mode commands specific to the currently selected mode. Type help to see all commands in every mode, or help mode for the currently available mode commands.
bridge
Transparent UART bridge. Bidirectional UART pass-through to interact with other serial devices from inside the Bus Pirate terminal. Press the Bus Pirate button to exit.
Help
HDPLXUART> bridge -h
usage:
bridge	[-h(elp)]
Transparent UART bridge: bridge
Exit: press Bus Pirate button
open UART with raw data IO, usb to serial bridge mode
-t	ENABLE toolbar while bridge is active (default: disabled)
-s	Suppress local echo, don't echo back sent data
-h	Get additional help
HDPLXUART>
