1-Wire Protocol
- Bus: 1-Wire
- Connections: one pin (OWD) and ground
- Output type: open drain/open collector
- Pull-up resistors: always required (2K - 10K ohms)
- Maximum voltage: 5volts
1-Wire is a common bus for low speed interfaces.
Configuration options
- None
Pull-up resistors
1-Wire is an open-collector bus, it requires pull-up resistors to hold the data line high and create the data ‘1’. 1-Wire parts don’t output high, they only pull low, without pull-up resistors there can never be a ‘1’.
Enable the Bus Pirate onboard pull-up resistors with the P
command.
1-Wire requires a pull-up resistor to hold the data line high.
1-Wire parts don’t output high, they only pull low.
Without pull-up resistors there can never be a ‘1’.
P
command.
Bus Pirate | Direction | Circuit | Description |
OWD | ↔ | OWD | 1-Wire Data |
GND | ⏚ | GND | Signal Ground |
Syntax
Command | Description |
{ or [ | Issue 1-Wire reset, detect device presence. |
r | Read one byte. (r:1…255 for bulk reads) |
0b | Write this binary value. Format is 0b00000000 for a byte, but partial bytes are also fine: 0b1001. |
0x | Write this HEX value. Format is 0x01. Partial bytes are fine: 0xA. A-F can be lower-case or capital letters. |
0-255 | Write this decimal value. Any number not preceded by 0x or 0b is interpreted as a decimal value. |
space | Value delimiter. Use a space to separate numbers. No delimiter is required between non-number values: {0xa6 0 0 16 5 0b111 0xaF rrrr}. |
(#) | Run macro, (0) for macro list. |
Bus Pirate 5 has global commands available everywhere, and mode commands specific to the currently selected mode. Type help
to see all commands in every mode, or help mode
for the currently available mode commands.
Most Bus Pirate commands have help. Add the -h
flag to any command to see the latest available options and usage examples.
scan
scan
performs a 1-Wire ROM search. Find all connected device IDs.
help
1-WIRE> scan -h usage: scan [-h(elp)] Scan 1-Wire address space: scan scan for 1-Wire devices -h Get additional help 1-WIRE>
use
1-WIRE> scan 1-Wire ROM search: 1: 28 5c aa 13 0a 00 00 19 1-WIRE>
scan
performs a 1-Wire ROM search to detect the ID of every connected 1-Wire device. They type of device is shown if the family ID is known.
ds18b20
ds18b20
reads the temperature from a single 18B20 sensor.
help
1-WIRE> ds18b20 -h usage: ds18b20 [-h(elp)] measure temperature (single sensor bus only): ds18b20 Query DS18B20 temperature sensor -h Get additional help 1-WIRE>
use
1-WIRE> ds18b20 RX: 1a 01 00 00 7f ff 06 10 12 Temperature: 17.625 1-WIRE>
Macro ds18b20
reads the temperature from a single 18B20 temperature sensor. The macro uses the skip ROM command, so it will only work with a single DS18B20 device connected.
