alt text
The Bus Pirate BPIO2 binmode is a FlatBuffers interface designed for simple and complete control of the Bus Pirate hardware from an application or script.
Pre-compiled BPIO2 FlatBuffer “tooling” is available for a bunch of common languages. This means you can easily integrate the BPIO2 protocol into your projects without needing to write extensive parsing or serialization code.
Why BPIO2?
Bus Pirate v3.x has a BBIO1 interface, an abbreviation for Bit Bang Input/Output. The interface was originally designed for simple bit-banging only, other protocols were hacked in later. If I may say so, it was a bit of a mess.
We could call this BBIO2, but it’s in no way similar to the original BBIO1 interface and it’s only marginally for bit-banging. Instead, we call it BPIO2 meaning the second generation of Bus Pirate I/O.
Configure BPIO2 binmode
SPI> binmode
Select binary mode
 1. SUMP logic analyzer
 2. BPIO2 flatbuffer interface
 3. Arduino CH32V003 SWIO
 4. Follow along logic analyzer
 5. Legacy Binary Mode for Flashrom and AVRdude (EXPERIMENTAL)
 6. IRMAN IR decoder (LIRC, etc)
 7. AIR capture (AnalysIR, etc)
 x. Exit
 > 2
Be sure to configure BPIO2 as the binmode. Type binmode in the Bus Pirate terminal, and select the BPIO2 flatbuffer interface. Optionally save BPIO2 as the default binmode when prompted.
BPIO2 is now available on the second serial port (the one not used by the terminal).
Python Library
Download the BPIO2 Python library and examples:
  • / - Example Python scripts using the library
  • /pybpio/ - Python library for BPIO2
  • /tooling/ - FlatBuffers generated Python tooling
  • /flatbuffers/ - FlatBuffers library for Python
Install
In addition to Python 3 or later, pyserial and COBS are required to use the BPIO2 library. You can install them using pip:
pip3 install -r requirements.txt
Client Show Status
The BPIO2 client has a show_status() method that sends a StatusRequest to the Bus Pirate and prints the StatusResponse.
  1. Import the BPIOClient class from the bpio_client module.
  2. Create an instance of the BPIOClient class, passing the serial port as an argument.
  3. Call the show_status() method to retrieve and print the status of the Bus Pirate.
>>> from bpio_client import BPIOClient
>>> client = BPIOClient("COM35")
>>> client.show_status()
StatusResponse:
  FlatBuffers version: 2.0
  Hardware version: 5 REV10
  Firmware version: 0.0
  Firmware git hash: unknown
  Firmware date: Aug 19 2025 13:07:05
  Available modes: HiZ, 1WIRE, UART, HDUART, I2C, SPI, 2WIRE, 3WIRE, DIO, LED, INFRARED, JTAG
  Current mode: I2C
  Mode bit order: MSB
  Pin labels: ON, SDA, SCL, , , , , , , GND
  Mode max packet size: 640 bytes
  Mode max write size: 512 bytes
  Mode max read size: 512 bytes
  Number of LEDs: 18
  Pull-up resistors enabled: True
  Power supply enabled: True
  PSU set voltage: 3299 mV
  PSU set current: 300 mA
  PSU measured voltage: 3300 mV
  PSU measured current: 3 mA
  PSU over current error: No
  IO ADC values (mV): 3312, 3316, 3312, 3304, 3300, 3291, 3280, 3285
  IO directions: IO0:IN, IO1:IN, IO2:IN, IO3:IN, IO4:IN, IO5:IN, IO6:IN, IO7:IN
  IO values: IO0:HIGH, IO1:HIGH, IO2:HIGH, IO3:HIGH, IO4:HIGH, IO5:HIGH, IO6:HIGH, IO7:HIGH
  Disk size: 97.69779205322266 MB
  Disk space used: 0.0 MB
Client Get Status
You can also get the status as a dictionary, and access the individual fields.
>>> status = client.status_request()
>>> print(status['error'])
None
>>> print(status)
   'error':None,
   'version_flatbuffers_major':2,
   'version_flatbuffers_minor':0,
   'version_hardware_major':5,
   'version_hardware_minor':10,
   'version_firmware_major':0,
   'version_firmware_minor':0,
   'version_firmware_git_hash':'unknown',
   'version_firmware_date':'Aug 19 2025 13:07:05',
   'modes_available':['HiZ','1WIRE','UART','HDUART','I2C','SPI','2WIRE','3WIRE','DIO','LED','INFRARED','JTAG'],
   'mode_current':'I2C',
   'mode_pin_labels':['ON','SDA','SCL','','','','','','','GND'],
   'mode_bitorder_msb':True,
   'mode_max_packet_size':640,
   'mode_max_write':512,
   'mode_max_read':512,
   'psu_enabled':True,
   'psu_set_mv':3299,
   'psu_set_ma':300,
   'psu_measured_mv':3329,
   'psu_measured_ma':2,
   'psu_current_error':False,
   'pullup_enabled':True,
   'adc_mv':[3320,3269,3267,3266,3283,3306,3309,3319],
   'io_direction':0,
   'io_value':255,
   'disk_size_mb':97.69779205322266,
   'disk_used_mb':0.0,
   'led_count':18
Mode Change
>>> from bpio_i2c import BPIOI2C
>>> i2c = BPIOI2C(client)
>>> i2c.configure(speed=400000, pullup_enable=True, psu_enable=True, psu_voltage_mv=3300, psu_current_ma=0)
True
There is a Python class for interacting with each mode such as I2C, 1-Wire and SPI. Initialize the mode class with a BPIOClient instance.
To enter and configure a mode use the configure() function. configure() accepts arguments for the mode configuration and other hardware settings. Here we set the I2C speed to 400kHz, enable pull-ups, and set the power supply to 3.3volts with no current limit. The method returns True if the configuration was successful, or False if there was an error.
Mode configuration arguments are reused for multiple modes, and correspond to the FlatBuffer mode configuration table names:
ParameterTypeDefaultDescription
speeduint3220000Speed in Hz or baud for the mode
data_bitsuint88Data bits for the mode (e.g., 8 for UART)
parityboolfalseParity for the mode (true for even parity, false for no parity)
stop_bitsuint81Stop bits for the mode (1 or 2)
flow_controlboolfalseFlow control for the mode (true for enabled, false for disabled)
signal_inversionboolfalseSignal inversion for the mode (true for inverted, false for normal)
clock_stretchboolfalseClock stretching for I2C mode (true for enabled, false for disabled)
clock_polarityboolfalseClock idle polarity for SPI mode (true for high, false for low)
clock_phaseboolfalseClock phase for SPI mode (false for leading edge, true for trailing edge)
chip_select_idlebooltrueChip select idle state for SPI and 3-wire modes (true for idle high, false for idle low)
submodeuint8-Submode for LED and INFRARED modes
tx_modulationuint32-TX modulation frequency for INFRARED mode
rx_sensoruint8-RX sensor configuration for INFRARED mode
Other hardware can be configured at the same time as the mode change, for example the power supply, and pull-up resistors. The parameter names are also identical to the FlatBuffer configuration request table names:
mode_bitorder_msbbool-Bit order MSB
mode_bitorder_lsbbool-Bit order LSB
psu_disablebool-Disable power supply
psu_enablebool-Enable power supply
psu_set_mvuint32-Set voltage in millivolts (psu_enable must = true)
psu_set_mauint16300Set current in milliamps, 0 for unlimited (psu_enable must = true)
pullup_disablebool-Disable pull-up resistors
pullup_enablebool-Enable pull-up resistors
io_direction_maskuint8-Bitmask for IO pin directions (1=modify this pin)
io_directionuint8-IO pin directions in 8 bit byte (1 output, 0 input)
io_value_maskuint8-Bitmask for IO pin values (1=modify this pin)
io_valueuint8-IO pin values in 8 bit byte (1 high, 0 low)
led_resumebool-Resume LED effect after setting with led_color
led_color[uint32]-LED colors in RGB format (0xRRGGBB)
print_stringstring-String to print in the Bus Pirate terminal (e.g. for debugging)
Mode Get Functions
Mode classes have getter functions that query Bus Pirate status information.
Get All Status Info
>>> status = i2c.get_status()
>>> print(status['mode_current'])
I2C
Version Information
MethodReturnsDescription
get_version_flatbuffers_major()intFlatBuffers version major number (BPIOx)
get_version_flatbuffers_minor()intFlatBuffers version minor number
get_version_hardware_major()intHardware version major number
get_version_hardware_minor()intHardware revision number
get_version_firmware_major()intFirmware version major number
get_version_firmware_minor()intFirmware version minor number
get_version_firmware_git_hash()stringGit hash of the firmware build
get_version_firmware_date()stringDate and time of firmware build
Mode Status
get_modes_available()listArray of all available mode names
get_mode_current()stringName of the currently active mode
get_mode_pin_labels()listArray of pin labels for current mode
get_mode_bitorder_msb()boolCurrent bit order (True for MSB first)
get_mode_max_packet_size()intMaximum FlatBuffers packet size for the current mode
get_mode_max_write()intMaximum number of bytes that can be written in one operation
get_mode_max_read()intMaximum number of bytes that can be read in one operation
Power Supply Status
get_psu_enabled()boolWhether power supply is enabled
get_psu_set_mv()intSet voltage in millivolts
get_psu_set_ma()intSet current limit in milliamps
get_psu_measured_mv()intMeasured voltage in millivolts
get_psu_measured_ma()intMeasured current in milliamps
get_psu_current_error()boolOver-current error status
Hardware Status
get_pullup_enabled()boolWhether pull-up resistors are enabled
get_adc_mv()listADC measurements for each IO pin in mV
get_io_direction()intIO pin directions bitmask (1=output, 0=input)
get_io_value()intIO pin values bitmask (1=high, 0=low)
get_led_count()intNumber of LEDs on the device
Storage Status
get_disk_size_mb()floatTotal disk size in megabytes
get_disk_used_mb()floatUsed disk space in megabytes
Usage Examples
>>> # Get hardware version
>>> print(f"Hardware: {i2c.get_version_hardware_major()}.{i2c.get_version_hardware_minor()}")
Hardware: 5.10
>>> # Get current mode
>>> print(f"Current mode: {i2c.get_mode_current()}")
Current mode: I2C
>>> # Get PSU voltage
>>> print(f"PSU voltage: {i2c.get_psu_measured_mv()}mV")
PSU voltage: 3300mV
>>> # Get IO pin directions
>>> print(f"IO directions: {i2c.get_io_direction():08b}")
IO directions: 00000000
All getter functions return None if there is an error or if the Bus Pirate is not properly configured.
Mode Set Functions
Mode classes have setter functions that configure the Bus Pirate hardware and settings.
Bit Order Configuration
MethodParametersDescription
set_mode_bitorder_msb()NoneSet mode bit order to MSB (Most Significant Bit) first
set_mode_bitorder_lsb()NoneSet mode bit order to LSB (Least Significant Bit) first
Power Supply Control
set_psu_disable()NoneDisable the Bus Pirate power supply
set_psu_enable(voltage_mv, current_ma)voltage_mv (int, default=3300)
current_ma (int, default=300)
Enable power supply with specified voltage and current limit
Pull-up Resistor Control
set_pullup_disable()NoneDisable pull-up resistors
set_pullup_enable()NoneEnable pull-up resistors
IO Pin Control
set_io_direction(direction_mask, direction)direction_mask (int)
direction (int)
Set IO pin directions (1=output, 0=input)
set_io_value(value_mask, value)value_mask (int)
value (int)
Set IO pin values (1=high, 0=low)
LED Control
set_led_resume()NoneResume previous LED effect after configuration using set_led_colors()
set_led_color(colors)colors (list)Set LED colors in RGB format (0xRRGGBB)
Utility Functions
set_print_string(string)string (str)Print string on Bus Pirate terminal
set_hardware_bootloader()NoneEnter bootloader mode
set_hardware_reset()NonePerform hardware reset of the device
set_hardware_selftest()NonePerform self-test of the Bus Pirate hardware
Usage Examples
>>> # Enable power supply at 5V with 500mA limit
>>> i2c.set_psu_enable(voltage_mv=5000, current_ma=500)
True
>>> # Set IO pin 7 as output and drive it low
>>> i2c.set_io_direction(direction_mask=0x80, direction=0x80)
True
>>> i2c.set_io_value(value_mask=0x80, value=0x00)
True
>>> # Set all LEDs to red
>>> i2c.set_led_color([0xFF0000] * 18)
True
>>> # Print debug message
>>> i2c.set_print_string("Debug: I2C configured")
True
Setter functions return True if successful, False if there was an error, or None if not configured
I2C Data
The BPIOI2C class provides support for I2C bus transactions.
Configuration
configure(speed, clock_stretch, **kwargs)speed (int, default=400000)
clock_stretch (bool, default=False)
**kwargs (additional config)
Configure I2C mode with specified speed and clock stretching
I2C Operations
start()NoneSend I2C start condition
stop()NoneSend I2C stop condition
write(data)data (list of bytes)Write data bytes to I2C bus
read(num_bytes)num_bytes (int)Read specified number of bytes from I2C bus
transfer(write_data, read_bytes)write_data (list, optional)
read_bytes (int, default=0)
Perform complete I2C transaction with start, write, restart, read, and stop
scan(start_addr, end_addr)start_addr (int, default=0x00)
end_addr (int, default=0x7F)
Scan I2C bus for devices in specified address range
Basic Configuration
>>> i2c.configure(speed=400000, clock_stretch=False)
True
Manual I2C Operations
>>> i2c.start()                   # Send start condition
>>> i2c.write([0xA0, 0x00])       # Write device address and register
>>> i2c.stop()                    # Send stop condition
>>> i2c.start()                   # Send start condition again
>>> i2c.write([0xA1])             # Write read address
>>> data = i2c.read(2)            # Read 2 bytes
Complete Transaction
>>> # Write to register 0x00 of device at address 0x50
>>> result = i2c.transfer(write_data=[0xA0, 0x00, 0x42])
>>> # Read 2 bytes from device at address 0x50, location 0x00 (e.g. 24x02 EEPROM)
>>> result = i2c.transfer(write_data=[0xA0, 0x00], read_bytes=2)
Bus Scanning
>>> devices = i2c.scan()
Scanning I2C bus from 0x00 to 0x7F...
>>> print(f"Found devices: {[hex(addr) for addr in devices]}")
Found devices: ['0xa0', '0xa1']
SPI Data
The BPIOSPI class provides support for SPI bus transactions.
Configuration
configure(speed, clock_polarity, clock_phase, chip_select_idle, **kwargs)speed (int, default=1000000)
clock_polarity (bool, default=0)
clock_phase (bool, default=0)
chip_select_idle (bool, default=1)
Configure SPI mode with clock settings and chip select polarity
SPI Operations
select()NoneSelect SPI device
deselect()NoneDeselect SPI device
write(data)data (list of bytes)Write data bytes to SPI device
read(num_bytes)num_bytes (int)Read specified number of bytes from SPI device
transfer(write_data, read_bytes)write_data (list of bytes)
read_bytes (int, optional)
Perform complete SPI transaction with select, write/read, and deselect
transfer_duplex(write_data)write_data (list of bytes)
Perform full-duplex (read with write) SPI transaction with select, write/read, and deselect
Basic Configuration
>>> from bpio_spi import BPIOSPI
>>> spi = BPIOSPI(client)
>>> spi.configure(speed=1000000, clock_polarity=False, clock_phase=False, chip_select_idle=True)
True
Manual SPI Operations
>>> spi.select()                  # Pull chip select low
>>> spi.write([0x9F])             # Send command
>>> data = spi.read(3)            # Read response
>>> spi.deselect()                # Pull chip select high
>>> # Send command 0x9F and read 3 bytes response
>>> result = spi.transfer(write_data=[0x9F], read_bytes=3)
>>> print(f"Device ID: {[hex(b) for b in result['data_read']]}")
Device ID: ['0xef', '0x40', '0x18']
1-Wire Data
The BPIO1Wire class provides support for 1-Wire bus transactions.
Configuration
configure(**kwargs)**kwargs (configuration options)Configure 1-Wire mode with additional hardware settings
1-Wire Operations
reset()NoneReset the 1-Wire bus and check for device presence
write(data)data (list of bytes)Write data bytes to 1-Wire device
read(num_bytes)num_bytes (int)Read specified number of bytes from 1-Wire device
Perform complete 1-Wire transaction with reset, write, and read
Basic Configuration
>>> from bpio_1wire import BPIO1Wire
>>> ow = BPIO1Wire(client)
>>> ow.configure()
True
Manual 1-Wire Operations
>>> ow.reset()                    # Reset bus and check for presence
>>> ow.write([0xCC])              # Skip ROM command
>>> ow.write([0x44])              # Start temperature conversion
>>> ow.reset()                    # Reset again
>>> ow.write([0xBE])              # Read scratchpad command
>>> data = ow.read(9)             # Read 9 bytes from scratchpad
>>> # Read temperature from DS18B20
>>> result = ow.transfer(write_data=[0xCC, 0x44])  # Skip ROM + convert
>>> # Wait for conversion...
>>> result = ow.transfer(write_data=[0xCC, 0xBE], read_bytes=9)  # Read data
>>> print(f"Temperature data: {[hex(b) for b in result[:2]]}")
Temperature data: ['0x50', '0x05']
DS18B20 Temperature Sensor Example
>>> # Complete temperature reading sequence
>>> ow.reset()
>>> ow.write([0xCC, 0x44])        # Skip ROM, start conversion
>>> # Wait 750ms for conversion
>>> import time
>>> time.sleep(0.75)
>>> ow.reset()
>>> ow.write([0xCC, 0xBE])        # Skip ROM, read scratchpad
>>> temp_data = ow.read(2)        # Read temperature bytes
>>> temp = (temp_data[1] << 8 | temp_data[0]) / 16.0
>>> print(f"Temperature: {temp}°C")
Temperature: 21.3125°C
UART Data
The BPIO2 protocol supports full-duplex UART (Universal Asynchronous Receiver/Transmitter) communication, enabling both synchronous transactions and asynchronous data monitoring. The UART interface is accessed via the BPIOUART class in the pybpio Python library.
Features
  • Configurable baud rate, data bits, parity, stop bits, flow control, and signal inversion
  • Synchronous data write/read operations
  • Asynchronous data monitoring (buffered or callback modes)
  • Real-time event-driven or polling-based data handling
Configuration
configure(speed, data_bits, parity, stop_bits, flow_control, signal_inversion, async_callback, **kwargs)speed (int, default=115200)
data_bits (int, default=8)
parity (bool, default=False)
stop_bits (int, default=1)
flow_control (bool, default=False)
signal_inversion (bool, default=False)
async_callback (function or None)
Configure UART mode with specified parameters and optional async callback
UART Operations
write(data)data (bytes or list)Write bytes to UART
transfer(write_data, read_bytes)write_data (bytes or list)
Perform combined write/read UART transaction, 1 second read timeout
read_async(clear_buffer)clear_buffer (boolean)Read any available async data from UART buffer (buffered mode only)
Basic Configuration
from pybpio.bpio_client import BPIOClient
from pybpio.bpio_uart import BPIOUART
client = BPIOClient('COM35')
uart = BPIOUART(client)
uart.configure(speed=115200, data_bits=8, parity=False, stop_bits=1, flow_control=False, signal_inversion=False, async_callback=None)
Synchronous Data Transfer
response = uart.transfer(b"Ping", read_bytes=4)
if response and 'data_read' in response:
    print(response['data_read'])
Write bytes, then attempt to read 4 bytes with a 1 second timeout.
Asynchronous Data Monitoring
1. Buffered Mode
uart.configure(..., async_callback=None)  # No callback
# ...send data...
time.sleep(1)
data = uart.read_async()
if data:
    print("Async RX:", data)
Async data is accumulated in an internal buffer and can be read at any time.
2. Callback Mode
def on_uart_data(data):
    print("Received:", data)
uart.configure(..., async_callback=on_uart_data)
# ...send data...
# Callback is called automatically when data arrives
You can also provide your own callback function to process async data as it arrives in real time.
LED Data
The BPIOLED class provides support for controlling RGB LEDs, including WS2812/SK6812/NeoPixel, APA102/SK9822, and the Bus Pirate’s onboard RGB LED (also a SK6812).
Configuration
configure(led_type, **kwargs)led_type (str or int)
Configure LED mode with specified LED type: ‘WS2812’, ‘APA102’, or ‘ONBOARD’ (or 0, 1, 2)
LED Operations
write(data, start_main, stop_main)data (bytes or list)Write raw data to LED device
set_rgb(r, g, b, brightness)r (int, 0-255)
g (int, 0-255)
b (int, 0-255)
brightness (int, 0-31, default=31)
Set single LED to RGB color (brightness only for APA102)
set_rgbw(r, g, b, w, brightness)r (int, 0-255)
g (int, 0-255)
b (int, 0-255)
w (int, 0-255)
Set single RGBW LED (WS2812 only)
set_multiple_rgb(colors, brightness)colors (list of (r,g,b) tuples)
Set multiple LEDs with RGB values (brightness only for APA102)
clear(num_leds)num_leds (int, default=1)Turn off LEDs (set to black/off)
  • start_main - RESET (WS2812/SK6812) or START FRAME (APA102)
  • stop_main - END FRAME (APA102)
By default these are set to True so each call is treated as a full LED string update. Set to False for advanced users who want to manage the timing and framing themselves.
Basic Configuration - Onboard LED
>>> from bpio_led import BPIOLED
>>> led = BPIOLED(client)
>>> led.configure(led_type='ONBOARD')
True
Basic Configuration - WS2812 External LEDs
>>> led.configure(led_type='WS2812', psu_enable=True, psu_set_mv=5000, psu_set_ma=0)
True
Basic Configuration - APA102 External LEDs
>>> led.configure(led_type='APA102', psu_enable=True, psu_set_mv=5000, psu_set_ma=0)
True
Single LED Control
>>> # Set onboard LED to red
>>> led.set_rgb(255, 0, 0)
>>> # Set first WS2812 LED to green
>>> led.configure(led_type='WS2812', psu_enable=True, psu_set_mv=5000)
>>> led.set_rgb(0, 255, 0)
>>> # Set first APA102 LED to blue at 50% brightness
>>> led.configure(led_type='APA102', psu_enable=True, psu_set_mv=5000)
>>> led.set_rgb(0, 0, 255, brightness=15)
Multiple LED Control
>>> # Rainbow pattern on 5 WS2812 LEDs
>>> rainbow = [
...     (255, 0, 0),    # Red
...     (255, 165, 0),  # Orange
...     (255, 255, 0),  # Yellow
...     (0, 255, 0),    # Green
...     (0, 0, 255),    # Blue
>>> led.set_multiple_rgb(rainbow)
>>> # Same pattern on APA102 with brightness control
>>> led.set_multiple_rgb(rainbow, brightness=20)
RGBW LEDs (WS2812 only)
>>> # Set RGBW LED with white channel
>>> led.set_rgbw(255, 0, 0, 128)  # Red + half white
Clearing LEDs
>>> # Turn off first LED
>>> led.clear(num_leds=1)
>>> # Turn off first 10 LEDs in a strip
>>> led.clear(num_leds=10)
Global Brightness Control (APA102)
>>> # Test different brightness levels (0-31)
>>> for brightness in [31, 15, 7, 3, 1]:
...     led.set_rgb(255, 0, 0, brightness=brightness)
...     time.sleep(0.5)
Write Raw Data to LEDs
LEDBytes per LEDBrightness ControlColor Format
WS28123 bytes (GRB)No0xGGRRBB
ONBOARD3 bytes (RGB)No0xRRGGBB
APA1024 bytes (bBGB)Yes (0xbb = 0-31)0xbbBBGGRR with brightness byte
Note that each supported LED has a different raw data format.
WS2812
>>> # Example raw data for 2 LEDs (6 bytes for RGB)
>>> raw_data = [255, 0, 0, 0, 255, 0]  # First LED red, second LED green
>>> led.write(raw_data, start_main=True, stop_main=True)
APA102
>>> # Example raw data for 2 LEDs (8 bytes for bBGB)
>>> raw_data = [0b11100000 | 31, 255, 0, 0, 0b11100000 | 15, 0, 255, 0]  # First LED bright red, second LED dim green
Debugging
[BPIO] Flatbuffer length: 64
[BPIO] Flatbuffer received, length: 64
[BPIO] Packet Type: 3
[Data Request] Start main condition: true
[Data Request] Start alternate condition: false
[Data Request] Data write vector is present
[Data Request] Data write vector length: 2
[Data Request] Data write: 0xA0 0x00
[Data Request] Bytes to read: 16
[Data Request] Stop main condition: true
[Data Request] Stop alternate condition: false
[Data Request] Protocol request
[I2C] Performing transaction
Detailed debugging information can be displayed in the terminal when BPIO2 requests are processed. This can help you understand how the protocol works and troubleshoot any issues.
FlatBuffers Tooling Download
Download precompiled FlatBuffer tooling, required includes, and demo libraries from the BPIO2 repo.
Compile your own tooling
To generate your own tooling from the BPIO2 schema, you can use a FlatBuffers compiler with bpio.fbs.
C language tooling
flatcc -a bpio.fbs
To generate C tooling, use the flatcc compiler. This is the version we use to generate C tooling for the Bus Pirate firmware.
Other language tooling
flatc --python bpio.fbs
For C++, C#, Dart, Go, Java, JavaScript, Kotlin, Lobster, Lua, PHP, Python, Rust, Swift, TypeScript use flatc.
FlatBuffers Includes
In addition to the generated tooling, you will need to include the FlatBuffers support library for your language. Check the /include/ folder in the BPIO2 repository for the required files.
COBS Encoding
FlatBuffers request and response packets are encoded using COBS (Consistent Overhead Byte Stuffing) to ensure that the data can be transmitted over serial without issues. COBS encoding replaces zero bytes with a special marker. When data is sent 0x00 indicates the end of a packet. Most languages have a simple COBS library available, for example the COBS Python library or the C nanocobs implementation.
Schema
BBIO2 uses Request and Response tables to communicate with the Bus Pirate.
  • The host device sends a Request to the Bus Pirate, which contains the operation to be performed.
  • The Bus Pirate processes the request and sends back a Response containing the result of the operation.
There are currently several Request and Response pair ’tables’:
  • StatusRequest/StatusResponse - Used to check the status of the Bus Pirate and read pin states.
  • ConfigurationRequest/ConfigurationResponse - Used to configure the Bus Pirate mode, settings and hardware.
  • DataRequest/DataResponse - Used to send and receive data to/from the Bus Pirate.
Additionally there are wrapper tables for the requests and responses:
  • RequestPacket - Contains the request type and the request data.
  • ResponsePacket - Contains the response type and the response data.
There is a table for mode configuration:
  • ModeConfiguration - Contains mode-specific settings, such as speed and other parameters.
Request & Response Packets
  • RequestPacket is the outermost table/wrapper for requests sent to the Bus Pirate.
  • ResponsePacket is the outermost table/wrapper for responses sent by the Bus Pirate
RequestPacket
union RequestPacketContents { StatusRequest, ConfigurationRequest, DataRequest}
table RequestPacket {
  version_major:uint8;
  minimum_version_minor:uint16; // Minimum version minor for compatibility.
  contents:RequestPacketContents;
RequestPacket contents field contains one of the request tables (StatusRequest, ConfigurationRequest, DataRequest). This packet is sent from the host to the Bus Pirate.
version_major should be set to 2 for the current BPIO2 FlatBuffers tooling. version_major is used to indicate breaking changes in the protocol.
minimum_version_minor tells the Bus Pirate the minimum BPIO2 FlatBuffers tooling version required by the host. If the Bus Pirate firmware has a lower version, it will return an error in the ResponsePacket. This is used to provide clear compatibility error messages to the user, rather than silently failing or returning unexpected results.
ResponsePacket
union ResponsePacketContents {StatusResponse, ConfigurationResponse, DataResponse}
table ResponsePacket{
  error:string; // Error message if any.
  contents:ResponsePacketContents;
ResponsePacket contents field, which contains one of the response tables (StatusResponse, ConfigurationResponse, DataResponse). This packet is sent from the Bus Pirate to the host in response to a RequestPacket.
If there was an error processing the RequestPacket, the error field will contain a string describing the error. If there was no error, the error field will be empty.
Examples of errors that might be returned include:
  • Invalid request type
  • Packet size too large
  • Timeout waiting for request
  • FlatBuffers version_major or minimum_version_minor mismatch
Status
  • StatusRequest queries the current status of the Bus Pirate.
  • StatusResponse contains the requested status information.
StatusRequest
enum StatusRequestTypes:byte{All, Version, Mode, Pullup, PSU, ADC, IO, Disk, LED}
table StatusRequest{
  query:[StatusRequestTypes]; // List of status queries to perform.
StatusRequest has a single field, query, which is an array of StatusRequestTypes. All returns everything, while the other types return specific queries which reduces the size and latency of the StatusResponse.
StatusResponse
// returns the status queries requested in StatusRequest
// if query is empty, then all queries are performed
table StatusResponse {
  version_flatbuffers_major:uint8; // Flatbuffers version major.
  version_flatbuffers_minor:uint16; // Flatbuffers version minor.
  version_hardware_major:uint8; //HW version
  version_hardware_minor:uint8; //HW revision
  version_firmware_major:uint8;//FW version
  version_firmware_minor:uint8; //FW revision
  version_firmware_git_hash:string; //Git hash of the firmware.
  version_firmware_date:string; //Date of the firmware build.
  modes_available:[string]; // List of modes available on the device.
  mode_current:string; // Current mode name.
  mode_pin_labels:[string]; // Labels for the pins in the current mode.
  mode_bitorder_msb:bool; // Bit order for the current mode (true for MSB first, false for LSB first).
  mode_max_packet_size:uint32; // Maximum flat buffer packet size for the current mode.
  mode_max_write:uint32; // Maximum data write size for the current mode.
  mode_max_read:uint32; // Maximum data read size for the current mode.
  psu_enabled:bool; // Power supply enabled.
  psu_set_mv:uint32; // Power supply set voltage in millivolts.
  psu_set_ma:uint32; // Power supply set current in milliamps.
  psu_measured_mv:uint32; // Measured power supply voltage in millivolts.
  psu_measured_ma:uint32; // measured power supply current in milliamps.
  psu_current_error:bool; // Power supply fuse error.
  pullup_enabled:bool; // Pull-up resistors enabled.
  adc_mv:[uint32]; // IO pin ADC values in millivolts.
  io_direction:uint8; // IO pin directions (true for output, false for input).
  io_value:uint8; // IO pin values (true for high, false for low).
  disk_size_mb:float; // Size of the disk in megabytes.
  disk_used_mb:float; // Used space on the disk in megabytes.
  led_count:uint8; // Number of LEDs.
Depending on the query parameters, all of some of the fields in the StatusResponse will be populated. If an error occurs, the error field will contain a message describing the error.
Python Example
"""Send a StatusRequest packet and return the response"""
"""Wrap contents in a RequestPacket"""
# Create a flatbuffers builder
builder = flatbuffers.Builder(1024)
# Create the query vector BEFORE starting the StatusRequest table
StatusRequest.StartQueryVector(builder, 1)
builder.PrependUint8(StatusRequestTypes.StatusRequestTypes.All)
query_vector = builder.EndVector()
# Create a StatusRequest
StatusRequest.Start(builder)
StatusRequest.AddQuery(builder, query_vector) # Add the query vector
status_request = StatusRequest.End(builder)
# Create a RequestPacket
RequestPacket.Start(builder)
RequestPacket.AddVersionMajor(builder, 2)
RequestPacket.AddMinimumVersionMinor(builder, 0) # Update to match the minimum version tooling required
RequestPacket.AddContentsType(builder, RequestPacketContents.RequestPacketContents.StatusRequest) # Add the StatusRequest type
RequestPacket.AddContents(builder, status_request) # Add the StatusRequest
request_packet = RequestPacket.End(builder)
# Finish the builder and get the data
builder.Finish(request_packet)
data = builder.Output()
# COBS encode request and send to the serial port
resp_data = self.send_and_receive(data)
# Check for the response
if not resp_data:
    return False
# Decode ResponsePacket
resp_packet = ResponsePacket.ResponsePacket.GetRootAsResponsePacket(resp_data, 0)
# Check for ErrorResponse
if resp_packet.Error():
    print(f"Error: {resp_packet.Error().decode('utf-8')}")
    return False
# Confirm the response type matches expected
response_contents_type = resp_packet.ContentsType()
if response_contents_type != ResponsePacketContents.ResponsePacketContents.StatusResponse:
    print(f"Unexpected response type: {response_contents_type}")
    return False
# Decode StatusResponse
status_resp = StatusResponse.StatusResponse()
status_resp.Init(resp_packet.Contents().Bytes, resp_packet.Contents().Pos)
# Print hardware and firmware versions
print(f"  Flatbuffers version: {status_resp.VersionFlatbuffersMajor()}.{status_resp.VersionFlatbuffersMinor()}")
print(f"  Hardware version: {status_resp.VersionHardwareMajor()} REV{status_resp.VersionHardwareMinor()}")
print(f"  Firmware version: {status_resp.VersionFirmwareMajor()}.{status_resp.VersionFirmwareMinor()}")
print(f"  Firmware git hash: {status_resp.VersionFirmwareGitHash().decode('utf-8')}")
print(f"  Firmware date: {status_resp.VersionFirmwareDate().decode('utf-8')}")
# Print available modes
modes_available = [status_resp.ModesAvailable(i).decode('utf-8') for i in range(status_resp.ModesAvailableLength())]
print(f"  Available modes: {', '.join(modes_available)}")
The complete example is available in the BPIO2 FlatBuffers repo.
See flatc for language-specific usage instructions.
Configuration
  • A ConfigurationRequest configures the Bus Pirate settings and hardware.
  • A ConfigurationResponse contains any error message.
table ConfigurationRequest {
  mode:string; // Name of the mode to configure.
  mode_configuration:ModeConfiguration; // Configuration for the mode.
  mode_bitorder_msb:bool; // Bit order MSB.
  mode_bitorder_lsb:bool; // Bit order LSB.
  psu_disable:bool; // Disable power supply.
  psu_enable:bool; // Enable power supply.
  psu_set_mv:uint32; // Set voltage in millivolts (psu_enable must = true).
  psu_set_ma:uint16=300; // Set current in milliamps, 0 for unlimited (psu_enable must = true).
  pullup_disable:bool; // Disable pull-up resistors.
  pullup_enable:bool; // Enable pull-up resistors.
  io_direction_mask:uint8; // Bitmask for IO pin directions (1=modify this pin).
  io_direction:uint8; // IO pin directions in 8 bit byte (1 output, 0 input).
  io_value_mask:uint8; // Bitmask for IO pin values (1=modify this pin).
  io_value:uint8; // IO pin values in 8 bit byte (1 high, 0 low).
  led_resume:bool; // Resume LED effect after configuration.
  led_color:[uint32]; // LED colors in RGB format (0xRRGGBB).
  print_string:string; // string to print on terminal
  hardware_bootloader:bool; // Enter bootloader mode.
  hardware_reset:bool; // Hardware reset the device.
  hardware_selftest:bool; // Perform a self-test on the device.
The ConfigurationRequest table configures Bus Pirate settings and hardware.
ModeConfiguration
table ModeConfiguration {
  speed:uint32=20000; // Speed in Hz or baud for the mode.
  data_bits:uint8=8; // Data bits for the mode (e.g., 8 for UART).
  parity:bool=false; // Parity for the mode (true for even parity, false for no parity).
  stop_bits:uint8=1; // Stop bits for the mode (1 or 2).
  flow_control:bool=false; // Flow control for the mode (true for enabled, false for disabled).
  signal_inversion:bool=false; // Signal inversion for the mode (true for inverted, false for normal).
  clock_stretch:bool=false; // Clock stretching for I2C mode (true for enabled,  false for disabled).
  clock_polarity:bool=false; // Clock idle polarity for SPI mode (true for high, false for low).
  clock_phase:bool=false; // Clock phase for SPI mode (false for leading edge, true for trailing edge).
  chip_select_idle:bool=true; // Chip select idle (0=idle low, 1=idle high) for SPI and 3-wire modes.
  submode:uint8; // Submode for LED and INFRARED modes (e.g., "RGB", "IR TX", "IR RX").
  tx_modulation:uint32; // TX modulation for INFRARED mode
  rx_sensor:uint8; // RX sensor for INFRARED mode
A ModeConfiguration table must be provided when changing modes. Pass the name of the mode in the mode field of the ConfigurationRequest, and include a ModeConfiguration table in the mode_configuration field.
table ConfigurationResponse{
The ConfigurationResponse table error string will contain a message if there was a problem processing the configuration request. The error field will be empty if configuration was successful.
Python Example
"""Create a BPIO ConfigurationRequest packet"""
# Create a mode string
mode_string = builder.CreateString("SPI")
# Create a ModeConfiguration
ModeConfiguration.Start(builder)
ModeConfiguration.AddSpeed(builder, 1000000)
ModeConfiguration.AddChipSelectIdle(builder, True)
ModeConfiguration.AddClockPhase(builder, False)
ModeConfiguration.AddClockPolarity(builder, False)
ModeConfiguration.AddDataBits(builder, 8)
mode_config = ModeConfiguration.End(builder)
# Set the LED colors
led_colors = [0xFF0000, 0x00FF00, 0x0000FF, 0xFFFF00, 0xFF00FF, 0x00FFFF] * 3
ConfigurationRequest.StartLedColorVector(builder, len(led_colors))
for color in reversed(led_colors):
    builder.PrependUint32(color)
led_color_vector = builder.EndVector()
# Create the ConfigurationRequest
ConfigurationRequest.Start(builder)
ConfigurationRequest.AddMode(builder, mode_string)
ConfigurationRequest.AddModeConfiguration(builder, mode_config)
ConfigurationRequest.AddPsuEnable(builder, True)
ConfigurationRequest.AddPsuSetMv(builder, 3300)
ConfigurationRequest.AddPsuSetMa(builder, 300)
ConfigurationRequest.AddPullupEnable(builder, True)
ConfigurationRequest.AddLedColor(builder, led_color_vector)
config_request = ConfigurationRequest.End(builder)
RequestPacket.AddContentsType(builder, RequestPacketContents.RequestPacketContents.ConfigurationRequest) # Add the ConfigRequest type
RequestPacket.AddContents(builder, config_request) # Add the ConfigRequest
if not resp_data:
    return False
    return False
if response_contents_type != ResponsePacketContents.ResponsePacketContents.ConfigurationResponse:
    return False
# Decode ConfigurationResponse
config_resp = ConfigurationResponse.ConfigurationResponse()
config_resp.Init(resp_packet.Contents().Bytes, resp_packet.Contents().Pos)
# Print the error message if any
if config_resp.Error():
    print(f"Configuration error: {config_resp.Error().decode('utf-8')}")
Data
  • The DataRequest table requests a data transaction in the currently selected mode.
  • The DataResponse table contains any errors or data received while processing the request.
DataRequest
table DataRequest {
  start_main:bool; // Start condition.
  start_alt:bool; // Alternate start condition.
  data_write:[ubyte]; // Data to write
  bytes_read:uint16; // Number of bytes to read.
  stop_main:bool; // Stop condition.
  stop_alt:bool; // Alternate stop condition.
The DataRequest table has fields that mimic the general Bus Pirate bus syntax/commands: start, write, read, stop.
The goal is to do a complete transaction in a single request, such as writing and reading an I2C or SPI device. However, you have complete control over the transaction, so you can write, read, start or stop individually as well.
FieldBus Pirate SyntaxDescription
start_main[Any mode specific “start condition”: 1-Wire RESET, I2C START, SPI Chip Select, etc
start_alt{Any mode specific “alternate start condition”: SPI Chip Select Read with Write mode, 2WIRE Reset Pin, etc.
data_write0x00Write data (array) to the currently configured bus.
bytes_readrRead this many bytes from the currently configured bus.
stop_main]Any mode specific “stop condition”: I2C STOP, SPI Chip Deselect, etc.
stop_alt}Any mode specific “alternate stop condition”: currently unused.
DataResponse
table DataResponse {
  data_read:[ubyte]; // Data read from device
  is_async: bool = false;  // NEW 2.2: marks this as unsolicited async data
The DataResponse table error string will contain a message if there was a problem processing the data request. The data_read field will contain the data read from the device, if any.
New in 2.2: The is_async field marks this response as an unsolicited asynchronous data packet. This allows the Bus Pirate to send data to the host without a corresponding request, which is useful for modes like UART where data can be received at any time.
Python Example
"""Create a BPIO DataRequest packet"""
# Define the data to write
data_write = [0x9F]
data_write_vector = builder.CreateByteVector(bytes(data_write))
# Create a DataRequest
DataRequest.Start(builder)
DataRequest.AddStartMain(builder, True)
DataRequest.AddDataWrite(builder, data_write_vector)
DataRequest.AddBytesRead(builder, 3)
DataRequest.AddStopMain(builder, True)
data_request = DataRequest.End(builder)
RequestPacket.AddContentsType(builder, RequestPacketContents.RequestPacketContents.DataRequest) # Add the DataRequest type
RequestPacket.AddContents(builder, data_request) # Add the DataRequest
if not resp_data:
    return False
    return False
if response_contents_type != ResponsePacketContents.ResponsePacketContents.DataResponse:
    return False
# Decode DataResponse
data_resp = DataResponse.DataResponse()
data_resp.Init(resp_packet.Contents().Bytes, resp_packet.Contents().Pos)
if data_resp.Error():
    print(f"Data request error: {data_resp.Error().decode('utf-8')}")
    return False
# Return data read, if any
if data_resp.DataReadLength() > 0:
    data_bytes = data_resp.DataReadAsNumpy()
    print(f"Data read: {' '.join(f'{b:02x}' for b in data_bytes)}")
I2C DataRequest
Start, stop, write and read can all be done individually, or as a complete I2C write/read transaction. I2C data requests have a few special considerations:
  • If start_main is true, the Bus Pirate will send a start condition
  • In a full transaction the first byte of data_write is used as the 8 bit I2C address. The I2C Read/Write bit is set and cleared automatically.
  • If start_main is true and data_write has more than one byte (the I2C address), the Bus Pirate will send the first byte as the I2C address and write the rest of the bytes as data.
  • If data_write has more than one byte and bytes_read is greater than 0, the Bus Pirate will send an I2C RESTART.
  • If start_main is true or an I2C RESET was sent: when bytes_read is greater than 0, the Bus Pirate will send the I2C Read address (data_write byte 0) and then read the requested bytes from the I2C device. If stop_main is true, the Bus Pirate will NACK the last byte read.
  • If stop_main is true, the Bus Pirate will send a stop condition.
This is a bit confusing at first, but it allows you to do a complete I2C transaction in a single request, or to control the transaction manually by sending partial requests.
